D3 bypass troubleshooting tips
By esb · Apr 08, 2007in Problems/Troubleshooting💬 3 posts👁️ 1,079 views
Posted Apr 08, 2007 · 15:54 UTC#1
I just installed my D3 with bypass and thought I'd share some troubleshooting tips to verify the different parts of the bypass procedure were done correctly. Here are some possible failures:
* Error message displayed while driving about incorrect installation relating to the parking brake
- Parking brake wire grounded, but mute wire not grounded in new harness location.
- Make sure mute wire is connected to vehicle ground and inserted into new harness location
* Video & destination selection does not work while driving. NAVI Menu -> Settings -> Hardware Info -> "Parking Brake" set to "Off"
- Parking brake wire not grounded
- Make sure parking brake wire is connected to vehicle ground and *NOT* connected to the actual parking brake signal.
* Audio is muted
- Mute wire is connected to vehicle ground, but has not been moved to the new harness location.
*** Not totally sure about this failure mode as I did not experience it myself. It may not behave this way when the mute wire is grounded.
Posted Apr 08, 2007 · 16:12 UTC#2
Always good for clarification.
Posted Apr 08, 2007 · 16:47 UTC#3
Thank you.
Sticky?
