WOULD OR HAS ANYONE FOUND A WAY TO HOOK UP THE VSS WIRE IN A HONDA ELEMENT 2007 MODEL? PLEASE HELP!!!
Posted Apr 08, 2007 · 17:19 UTC#1
this is for an 06, dont know if it has changed
Speed Sense blue/white ac ECM/PCM behind glovebox, pin E26
Im pretty sure its in the main wiring harness to the factory stereo. Should be blue.
No the 06 is not he same at all.We had a 06 and traded it for the 07 but they changed all the Element is now drive by wire !
Honda went to a shaft speed sensor. Like the Ridgeline. Use an abs sensor wire.
