Pac controller question
By BlackArmada · Apr 09, 2007in General💬 5 posts👁️ 754 views
Posted Apr 09, 2007 · 00:01 UTC#1
Which exactly is the wire I have to use for pac controller.Is is the radio harness itself or a different one.06 armada le
Posted Apr 09, 2007 · 00:27 UTC#2
Go to PAC's website. It'll give you exact instructions for your car.
Posted Apr 09, 2007 · 05:37 UTC#3
instructions are fully supplied as well with the product. its typically a single wire, or two at the most.
Posted Apr 09, 2007 · 15:58 UTC#4
It's on one of the plugs you took off the OEM radio. Use the instructions from pac and find the plug with those colors (MAKE SURE TO COUNT THE PINS) to get the correct connection. You might want to do this before you connect everything else. Go to CLUBTITAN .COM and search PAC Install. Someone has a pic of an install.
K
Posted Apr 09, 2007 · 22:08 UTC#5
the pac piece COMES WITH everything you need. theres a picture, theres the wire color, theres even the pin number. Just have to read the instructions provided with the product
