Power/Ground Install Questions
By mlammert · Apr 09, 2007in General💬 4 posts👁️ 926 views
Posted Apr 09, 2007 · 13:22 UTC#1
I have installed about 4-5 after market radios, but all of them were just straight radio replacements... Harness to harness and it was done...
My new D3 is the fist where I have multiple components: Bluetooth, Camera, Steering Wheel Interface, CD-Changer, etc...
Question:
1) What is the best way to ground all this, bundle all together and solder and attach to ground in harness??? Or, is there a better practice???
2) For all the component's power requirements (CD-Changer, Camera, Bluetooth, Steering Wheel Interface), is it okay to tap off of the harness's power??? Or, should I run a dedicated fused line from the vehicle's battery for the extra components???
I was laying out all the various harnesses and whatnot over the weekend and there are a lot of wires to connect... :shock:
Also, I think I am going to try and solder all my connections and cover with heat shrink...
All my other radios I put together with what I believe are called crimp-on butt-connectors...
Thanks for all the advice as always,
Mark
Posted Apr 09, 2007 · 13:27 UTC#2
Hi,
Attaching to hear input. I agree on splicing/heat shrink. That seems to be the best way to go for connecting the harnesses.
Posted Apr 09, 2007 · 21:10 UTC#3
recommend running a common ground for that equipment
to a near by frame or other such location. I ve never had a problem
running a few small components(head unit+sat+ipodetc...)off
of the 12v+in the factory harnes---but if i am running more than
just a few or its a top end install-I will rrun a seperate fused
12ga. from the battery.
g/l
I know all the wiring gets overwhelming--i usaully will
build a harness on the work bench --as far as i can go
then put it in the vehicle
Posted Apr 09, 2007 · 21:42 UTC#4
Thanks brianas,
Yeah, I am laying out all the wiring on my kitchen table and making all the capable connection there...
I originally used crimp connectors for everything... I am going to redo it and solder everything...
Rather redo it on my kitchen table than a couple months down the road and have to yank everything... Or, try and trouble shoot from my dashboard...
Sounds like I should be fine running everything through the radio harness...
Thanks again for the info,
Mark
