Pix: AVIC-D3 in a Hummer H2
By bullseye · Apr 10, 2007in General💬 12 posts👁️ 2,851 views
Posted Apr 10, 2007 · 03:25 UTC#1
Just got everything hooked up and working nice, with steering wheel controls. This is really a fun system!! Great NAV, iPod video, game console input, 17" widescreen rear LCD, and the front/rear screens can watch the same or 2 different things. :D Check it out! Thanks AVIC411 for the info and Crutchfield for the smokin deal!!
D3_6.jpg[/url]
Posted Apr 10, 2007 · 04:14 UTC#2
Looks nice.
I'm sure the camera has got to be a big help in that truck.
Posted Apr 10, 2007 · 04:17 UTC#3
yeah I like the setup...Looks clean
Posted Apr 10, 2007 · 12:44 UTC#4
Very nice.
Could you show some pics of where you mounted your actual backup camera?
Posted Apr 10, 2007 · 17:46 UTC#5
wow. looks really good.
Posted Apr 12, 2007 · 05:07 UTC#6
Thanks for the comments!
Hey Bobbo, here's a pic of the back side where you can see the camera mounted above the license plate.
Posted Jun 09, 2007 · 15:53 UTC#7
Looks great Bullseye. :D
I just had my AVIC-D3 "professionally" installed in my '07 H2, but they did NOT hook up the VSS. NAV is off quite a bit.
I will have them re-do it this week.
Question: Do you have a link/info on the VSS wiring for the Hummer H2?
Thanks.
Posted Jun 24, 2007 · 18:02 UTC#8
Update: Pix of AVIC-D3 stolen
It really sucks when you work hard on something then some jackass has to ruin it. I've got insurance to replace it all, but still a pain, and the next time I will have some suprises when they try it again!
Posted Jun 24, 2007 · 18:10 UTC#9
Man that sucks!!! :( This is a constant worry for me as well. It looks like there is not to much damage to the interior of the vehicle that cant be easily replaced. It also looks like the perp left the nav antenna as well. Hopefully the person has a hard time selling or gets nothing for because of that.
Posted Jun 24, 2007 · 18:17 UTC#10
I wonder how long it took him to steal the unit. Good thing 3000gts are so close to the ground, most people are too lazy to squat and take a look inside.
Posted Mar 18, 2008 · 03:27 UTC#11
Hey bullseye,
I was just wondering what you used for the radio mount kit? I installed a D3 into an 03 H2, everything went fine, but having some complications with fitting in the unit with the GMOS04 plug/wiring and the harnesses and wiring from the unit itself. I purchased the Metra mounting kit, and its the appropriate kit, and I can make it work -- but would like to find a cleaner setup.
Also, in the bypass... just to make sure since you're in a H2 also, did you just ground the parking brake and add the wire above the mute wire on the harness? And that wire thats added, thats just grounded out? And can I have the VSS sensor connected or does that need to be grounded as well?
I have it "temporarily" installed now, just cant watch dvd or use navi while driving... I had grounded out the parking brake, and overlooked the other stuff, but have to pull it back out for steering control harness anyways, so I can make the adjustments.
Your setup looked great though, sorry to see what happened.
Steve
Posted Mar 18, 2008 · 22:07 UTC#12
This is what I am curious about, unless your hooking a different source to your rear screen directly.
