weird bypass?
By nexus24 · Apr 11, 2007in Hacks/Mods💬 14 posts👁️ 3,605 views
Posted Apr 11, 2007 · 02:15 UTC#1
I bypassed my avic-d3 just as the picute and slide show said to do so but when I drive it tells me the parking break lead inst connected right.
When I restart the d3 it works for about 1-2hours or until the next time i shut the car off, when I power it on it tells me the parking break lead isnt connect right again..?
weird..
what to do?
Posted Apr 11, 2007 · 02:16 UTC#2
check your connections
Posted Apr 11, 2007 · 02:21 UTC#3
but what could be the problem?
Posted Apr 11, 2007 · 02:25 UTC#4
Bad connections.
Posted Apr 11, 2007 · 05:31 UTC#5
when I ground the parking break lead does it have to be by itself or can it be with the other grounded wires?
Posted Apr 11, 2007 · 05:43 UTC#6
it doesn't matter... just ground them all... it's EASIER to do it together... but if you want to ground one to your battery, then your parking brake wire to your cigarette lighter, then the mute wire to a beam in your roof do that... in the end... it all goes back to the negative battery post
Posted Apr 11, 2007 · 06:11 UTC#7
I was just asking, cause I grounded them all together and its giving me that problem, going to open it up tomorrow and check the connection.
Posted Apr 11, 2007 · 16:29 UTC#8
Be sure you are actually grounding it and not just attaching it to a ground wire that isn't grounded to something.
In my car (03 mustang) I just used wire taps to connect the parking brake, mute wire, and bluetooth ground to the black ground wire from the wiring harness.
In fact, my harness has two ground wires, chassis ground and amp ground. I used chassis ground but it really doesn't matter. Ground is ground.
Posted Apr 11, 2007 · 17:14 UTC#9
mine are all grounded to my stereo harness ground no point in running more cables and making a bigger mess.
Posted Apr 11, 2007 · 20:10 UTC#10
In your case there's a big difference between amp ground and chassis ground. The amp ground is a ground input for the factory amp if the car has one. In other words, not a true ground.
Posted Apr 12, 2007 · 02:22 UTC#11
Good thing I didn't use that one! So you are saying that amp ground doesn't ground?
Posted Apr 13, 2007 · 01:51 UTC#12
That wire must go to ground in order for the factory amp to turn on.
Posted Apr 17, 2007 · 22:21 UTC#13
CONFIRMED it does work.
somehow my wire came loose and it looked as if it was in yet it never clicked in. The ground wires were fine it was just the mute wasn't fully placed in.
Posted Apr 18, 2007 · 00:57 UTC#14
Congrats! Enjoy your movies, but be safe. :)
