Absolutely devastated....
By brandon · Apr 11, 2007in General💬 17 posts👁️ 3,686 views
Posted Apr 11, 2007 · 13:02 UTC#1
I had no idea that the z2 couldnt "rip" an mp3 cd like it does with a regularly store bought cd. Apparently, according to the manual, it doesnt like cdr's at all. Dont suppose anyone has found a different burning method or something to get around this have they? Or is a HDD hack the only way to get the mp3s on there?
Posted Apr 11, 2007 · 13:14 UTC#2
buy an ipod
Posted Apr 11, 2007 · 14:03 UTC#3
you cannot get mp3s on the hard drive no matter what. Pioneer uses some different compression file when it rips audio onto their hard drive.
Posted Apr 11, 2007 · 15:46 UTC#4
buy an ipod
I have an ipod. But thanks for being helpful. :roll:
Posted Apr 11, 2007 · 15:50 UTC#5
So, from what I understand most burning software can burn cds in wav format at 44.1khz and 16bit PCM, so I should be able to just burn in wav format using Nero. Hopefully... lol.
Does anyone know if the same applies for say the m3u file? If I were to burn the m3u file would the cd be in wav format? Or mp3?
Posted Apr 11, 2007 · 16:07 UTC#6
Try burning your CDs using the musicmatch jukebox burner. That's what I've done, and it records them onto the hard drive with no problems. Just make sure you label the cd before you burn or when it records it will be named whatever the burner names it, like disc1-41107.
Posted Apr 11, 2007 · 17:30 UTC#7
Use Nero, but make an audio cd. Not data.
As for .m3u files, those are playlist files. So, although they may reference actual music files, that format in itself is worthless in regards to the Z2.
Posted Apr 11, 2007 · 18:03 UTC#8
Yup, I just found that out for myself a minute ago. Had a cd that I made using the "make an audio cd" option, and sure enough it worked just like a store bought cd. As for the m3u file, yeah you're absolutely right, I dont know what I was thinking. Thanks for the help. :D
Posted Apr 11, 2007 · 23:56 UTC#9
If you use rewritable discs, you can erase it over and over and put new songs on the Z2. :)
Posted Jun 22, 2007 · 20:39 UTC#10
you can burn a music cd and then copy it to your z1, I have done this alot of times, I will burn a cd from itunes and then copy it to my z1. But you can't copy an mp3 files.
Posted Jun 22, 2007 · 20:59 UTC#11
I transfered a CD-r burned in iTunes, worked with no flaw. Used EQ cds.
Posted Jun 22, 2007 · 21:25 UTC#12
thats because you made an audio cd with your itunes
Posted Jun 22, 2007 · 22:08 UTC#13
Right. But i was responding to the comment about cdr's not working.
Posted Jun 23, 2007 · 00:28 UTC#14
I have the Z2 and burned an audio cd and it worked flawlessly when i ripped it....
Posted Jun 23, 2007 · 00:29 UTC#15
your all answering a post thats over two months old :lol:
Posted Jun 23, 2007 · 04:24 UTC#16
Sorry i just look at main page... what ever comes up as recent comments i asnwer to. OOOPPS !!!
Posted Jun 23, 2007 · 04:30 UTC#17
And you've never done that? :wink: It happens, hell I know I've done it on more than one occasion. The sad part is I took part in the thread originally too.
