Do I need to obtain another unit to plug into the AVIC D3 in order to receive XM Radio? If so, what unit goes with the D3? If not, how do I get into the XM section so I can get the radio code and set up my XM Radio? Thanks so much!
~Keith
~Keith
By "XM ready" they mean it has the capability to have XM, but does not come stock. Just liek when TVs say HD tuner ready, or when other radios say bluetooth ready and ipod ready.
Yes you will have to buy another external unit, which is easy, because they only make one that is meant to work directly with the unit. Go to their website and hit accessories when you are viewing the D3 page. You cant miss it.
Yeah, I just called and also looked on their site. They actually make two different units. One is just XM Radio and the other is XM Radio and XM Nav Traffic combined. I'm looking for the Nav Traffic option online now. I'm a little upset about having to run another antenna though. I wish nav and xm could just work off the same antenna. I'm very limited on space and routing options. Any idea if I can put the two antennas side by side or do they have to be a certain distance away from eachother?
~Keith
Um...NavTraffic and XM radio do use the same antenna. You are thinking of the GPS signal which uses a separate antenna. NavTraffic is provided by XM, so they use the same antenna.
I'm talking about my Avic antenna for nav, plus the XM antenna which makes two different antennas.
~K
For best reception, put your xm antenna on the roof.
Yes, that is the most important note. XM and sirius antennas need to go outside the car. GPS signals are available through many satelites, but XM is only available in a few.
wow definately a coocho
xm ready hahha
I thought that is where all GPS antennas have to go? That's where I already have my navi antenna mounted. I have te wiring underneath the weather stripping on my dirvers side t-top. I was going to run the XM Nav Traffic antenna the same way but on the passenger side. Then have the two antenna meet eachother side by side in the middle of the roof right behind the "T". Would that be sufficient or do I need to distance the two antennas a certain amount to get optimal reception?
~Keith
~Keith
You don't necessarily need your GPS antenna to be on your roof. Most have chosen to mount their antennas in their dash/on top of their dash. I have mind mounted within my dash and I get a good signal. I have only one antenna on my roof; my XM one.
~Keith
Well this is good news... maybe I will just place my navi antenna inbetween my roof behind the t-top and my headliner. This way it is still stuck to the metal roof. I'm sure it being upside down shouldn't make any difference right?
~Keith
Well, I'm certainly not the expert here, but I believe you don't want any metal between your NAV antenna and the sky (i.e. your roof). My dash is plastic. I mounted the included magnetic square upside down underneath the dash and I stuck my NAV antenna onto that.
Ahhh, I gotcha. I just thought it would use the car as a receiver and wouldn't make a difference so long as it is mounted on metal. Well, I guess I'll just leave it where it is and then call pioneer to see if the two antenns can be mounted next to eachother... Thanks for all your help with this!
~Keith
My GPS attenna is in the bottom corner of my dash and gets great reception. The XM's up on the roof...
