01 Pathfinder D2 install
By supraholic · Apr 11, 2007in Problems/Troubleshooting💬 4 posts👁️ 1,100 views
Posted Apr 11, 2007 · 17:58 UTC#1
I installed D2 into my 01 Nissan Pathfinder replacing the Double Din Bose system. It turns out that, the factory system was little bit bigger than the D2. So, after install, I have about a 1/2" gap at the bottom of the D2 and the dash trim. Any ideas how to hide it?
Posted Apr 15, 2007 · 02:21 UTC#2
sheet of abs plastic
Posted Apr 15, 2007 · 04:50 UTC#3
Or one of the trim plates that comes with a z1/d3. Used those a few times. Or the eclipse condom too.
Posted Apr 16, 2007 · 21:50 UTC#4
Thanks for the replys.. I ended up using metra 95-7417 kit suggested by a local audio installer.. It bearly covered the slot around the radio especially the bottom.. It works..
