What is the best way you guys found to clean your avic Lenses????
(i have the N1 w/ N3 software)
a new thing called WINDEX
Thanks man...nice sarcasm...So that means I have to take the unit apart?
yeah, most fingerprints are on the inside of the screen ![]()
I assume you are talking about the laser lens that reads disks. Misfit read the problem. You can purchase a dvd / cd cleaner disk. This disk has a small brush imbedded into the disk, which when played electrostatically removes dust from the lens. This will not remove finger prints from a lens, but the only way they are going to be on there is if you have opened the unit up and touched the lens. If you do have a super dirty lens or finger prints on it, then the only way I know to clean it is to open the unit and clean the lens eye with a cue tip and some windex, thanx misfit LOL. If this method is used be very careful not to scratch the lens. Hope this helps out. These disks can be found at best buy, frys or most audio or computer stores.
hey thanks for putting your two cents in on a two week old post thats been forgotten about, dick ![]()
