Hey guys I want to install the d3 on my new 07 Altima but when I got to the store and they tell me they couldn't do it because I had bose on there and they said I would have to get all new speakers, but I have others saying that they were able to have it done. Does anybody know for sure if it can be done and if so how? Thanks in advance for any help
2007 Altima W/BOSE
Radio 12vyellow/red radio harness
Radio Ground (chassis)
Radio Ignition purple/yellow + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on black/pink to black/green + radio harness
Power Antenna black - radio harness
LF Speaker +/- white - black +,- radio harness or amp under rear deck
RF Speaker +/- green/white - brown +,- radio harness or amp under rear deck
LR Speaker +/- orange/black - white/red +,- radio harness or amp under rear deck
RR Speaker +/- blue - black/white +,- radio harness or amp under rear deck
On vehicles with amplifier, the LF tweeter wires are lt. green - black/yellow.
The center channel speaker wires are black/pink - orange/black.
On vehicles with amplifier, the RF tweeter wires are blue/orange - gray/blue.
On vehicles with amplifier, the LR speaker wires are red/green - brown/black.
On vehicles with amplifier, the LH subwoofer wires are white/black - green/black and the RH subwoofer wires are brown/white - brown.
Thanks I don't really understand that but I'm sure who ever installs it will. I have one more question. Do you know if the factory bluetooth works with the D3 and does the steering wheel controls interact with the D3.
P.S. Does anybody know where I can get a D3 Installation kit for the 07 Altima, or is it not even being made
If you get the wire harness that is the colors you use to match up. If i am correct, If you have the factory BT then you will lose that feature. You will need the BT200.
What do you mean by getting the wire harness will i need to buy that seperatly
Yes. When you unhook the harness from the OEM radio, your new hareness will plug into the factories. Just match the colors of the wires and you will be good to go.
K
Cool alright. I have one last question do you know how big the D3 is from corner to corner, side to side, and top to bottom not just the screen but the whole thing.
I have an 07 Altima and they don't make dash kits for my car so i'm gonna see if factory dash kit of an Altima with navigation will fit with the D3
Need a pic. I test drove an 07 3.5 and if I remember correctly you might be able to use the nav bezel. try using http://www.yournissanparts.com
Also try this http://www.courtesyparts.com call if not showing
They might have it. If not on site call the number they have good CSR's and might be able to find it. Also try metra. You'll have to google that one.
K
you'll probably still have to make mods. most factory navs are bigger. but you can do it
Yeah the factory one screen size is 6.5 and the D3 is 6.1 but that's only the screen but I'm gonna try it out i'll let ya'll know
