btb200 problem with d3
By Mjdive · Apr 12, 2007in General💬 9 posts👁️ 1,541 views
Posted Apr 12, 2007 · 04:06 UTC#1
Hi,, I installed my d3 and btb200 today. I love this thing just need to check all th options out. Any way my bluetooth isnt' working. I was reading the maunal to try to set my phone up. You have to pair it with the d3. I just don't know what I need to do to pair it. The first instruction says to touch the phone connect on the function menu. Then it says to touch search for available phones. The only problem there is no search button. So now what? I have tried to reset the bluetooth unit as well as the d3 and the same thing happens. I have checked and rechecked my yellow 12v and the ground as well and they are good. also how do I know if my btb200 is correctly connected to my d3? The bt button is highlighted on the d3 any suggestions john
Posted Apr 12, 2007 · 13:42 UTC#2
Do you have bluetooth turned on, on your phone?
You need to make your phone discoverable.
Posted Apr 12, 2007 · 19:24 UTC#3
Kind of phone? Carrier?
Posted Apr 13, 2007 · 21:05 UTC#4
Usually you have to "search" for the BT signal (coming from your HU) so put the HU in pair mode and search for it on your phone...
Posted Apr 13, 2007 · 21:22 UTC#5
While we are talking about the BTB200, can you use voice activation on it? if so how? Cant figure it out?
Posted Apr 14, 2007 · 03:34 UTC#6
Yes, If you have voice activation on your phone
Posted Apr 14, 2007 · 19:55 UTC#7
How do you? I have voice activation but I can't seem to get it to work. I have a motorola v3c.
Posted Apr 15, 2007 · 00:09 UTC#8
thanks for the info i figured it out, how i do not know but i did. :lol:
Posted Apr 15, 2007 · 00:10 UTC#9
as far as voice calling i havent figured that out yet
