I wanted to make custom wallpapers for my Z2, what's the pixel size for it to fit perfect? The actual spec size is different when inputting those numbers in photoshop. Thanks!
Screen Resolution for Z2
The stock images are 500x240. They are bitmaps. That will fill up perfectly but the image will be stretched slightly cause the pixels are not perfectly square. So you have to make your images wide, and they will look fine on the screen.
big mahalo ducatiboy, now i can start designing some wallpaper n stuff. i'll post here some when I'm done.
If you want I posted some here:
http://www.sminntech.com/z1backgrounds/
There is even a photoshop file with a ton of layers with backgrounds and some logo foregrounds if you want to use that to get started.
CLOSE THIS POST PLS, GOT ALL THE HELP I NEEDED, MAHALO EVERYBODY
We don't usually close posts when one person is done with them, in case someone else would like to ask or add something. But you are welcome.
or if coochos actually want to do a search, which will never happen but we can only hope.
