blue tooth problem
By Navman · Apr 13, 2007in Problems/Troubleshooting💬 20 posts👁️ 4,541 views
Posted Apr 13, 2007 · 02:24 UTC#1
Just bought and had Z2 professionally installed today. After leaving the install facility I made 6 calls to different people, both land lines and cell. Every person I connected with said my phone was terrible and wanted me to call them back. Apparently every person on the other end were getting static from me and an echo of their own voice, I did not here an echo on my end but did not hear everyword of the person on the other end, that varied from call to call (anywhere from not so bad to terrible). Further clarification, I varied my geographc location during these trials greatly.
I left message with installer but have not heard back from him.
Any feedback on this would be appreciated.
Posted Apr 13, 2007 · 02:30 UTC#2
This has been beaten to death around here. Do a search, you might find an answer to your problem.
Posted Apr 13, 2007 · 06:00 UTC#3
so it sounds like the Z2 bluetooth was never fixed.....call pioneer and they'll give you a bluetooth fix cd or you can search on this board for a downloadable fix file....
Posted Apr 13, 2007 · 06:06 UTC#4
Even with that fix, most people still said it sucked (I for one applied the update and still it is useless).
Sorry man, you're SOL.
Posted Apr 13, 2007 · 16:07 UTC#5
that's weird, i did my update and i called people and they said is was fine (no echos)...go figure...
where did you guys put the mic...
Posted Apr 13, 2007 · 19:51 UTC#6
The fix, likely won't work with a Z2 since it has an operating system version that is higher then the bluetooth fix (or newer Z1s for that matter). I've heard that a combination of mic placement and volume levels can help (I haven't gotten my BT adapter yet).
Posted Apr 13, 2007 · 21:26 UTC#7
just wondering if everyone having issues has their phones charging in the car or just chillin'?
I just installed my Z2 and had issues until i started using the car charger. it may be an issue of your phones strength/bluetooth capabilities not the head unit too...? I have a UTStarcom PPC6700 and it works great now that it has extra juice.
Posted Apr 13, 2007 · 23:07 UTC#8
I would try some different mic placements. Also I found that if you changed the phone/guidance speaker settings to left side only verses both sides the the echo can be decreased. This has seemed to work on most of our installs before and after the bluetooth update.
Posted Apr 15, 2007 · 17:03 UTC#9
I am having the same problem. Tried different locations for the mic and that did not help. Factory tells me maybe I have a bad bluetooth unit, I am going to replace it on Tuesday. I will let you know what I find. I am using a car charge with the phone and that does not help the problem.
Posted Apr 15, 2007 · 17:06 UTC#10
Posted May 18, 2007 · 19:01 UTC#11
Is there a way to make only the left speakers work (but only when using the bluetooth phone)? If so, could you let me know how?
Posted May 19, 2007 · 16:01 UTC#12
Yes, it is in the manual somewhere. If you hit the "AV" button and then choose "AV Settings" (or something like that) it is in that set of options. Sorry I'm not more specific. I'll write down the exact steps and wording next time I'm in my car.
Posted May 21, 2007 · 17:26 UTC#13
To my knowledge there is no way to direct phone outputs to speaker subset. The menu option weberjam is thinking of is for the voice guidance output (L,R,L+R). My cell works perfectly fine with the Z2, after some trial and error placement of the microphone.
Posted May 21, 2007 · 17:47 UTC#14
It's for both the cell and the navi outputs.
Posted May 21, 2007 · 17:49 UTC#15
weberjam was right it is in av settings/system settings.
Posted May 21, 2007 · 19:37 UTC#16
Thanks for the backup guys ;). BTW I've been told it helps to set the speaker output to the Right speakers as far as reducing echo, but your results may vary.
Posted May 21, 2007 · 20:29 UTC#17
anyone know about the Z1 bluetooth? If i purchase a Z2 bluetooth piece on ebay does it work with the Z1?
sorry im a newbie.
-Brett
Posted May 21, 2007 · 22:04 UTC#18
same unit just updated maps. blue tooth is the same.
Posted Jun 08, 2007 · 22:32 UTC#19
i have run into an issue on a z1. bluetooth works, i can get a blackberry to pair up with it, but no one can hear him, he can hear the other side, but the other people can't hear him. HELP!!!!
Posted Jun 08, 2007 · 23:46 UTC#20
check and make sure the mic is in the right port. I mistakenly had mine in the wrong port at first. there are 2 ports next to each other it is very easy to plug into the wrong one.
