2001 Civic EX
By kryngle · Apr 14, 2007in General💬 22 posts👁️ 2,693 views
Posted Apr 14, 2007 · 00:04 UTC#1
Hey everybody. Just got me the AVIC-D3 not to long ago but I was curious if it's easy to install or real hard??? Any DIY or anythin of that sort??? What do I need and so forth. Thanx in advance
Posted Apr 14, 2007 · 00:07 UTC#2
Radio 12v white/red radio harness
Radio Ground black - radio harness
Radio Ignition yellow/red + radio harness
Radio Illumination red/black + radio harness
Factory Amp Turn-on
Power Antenna
LF Speaker +/- grn/blk - lt. green radio harness
RF Speaker +/- grn/yel - gry/red radio harness
LR Speaker +/- blu/wht - blu/blk radio harness
RR Speaker +/- pink - blu/yel radio harness
Speed Sense white/green PCM
The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
Reverse Light green + driver kick panel
Posted Apr 14, 2007 · 02:09 UTC#3
Use a wire harness. 70-1721 and the dash kit is 99-7865. That'll make the avic look a lot better in the dash.
Posted Apr 14, 2007 · 13:16 UTC#4
Okay and I hope y'all don't bite my head off lol Im new to this and Im a ask a nOOb question. SORRY IN ADVANCE :oops:
But what MisFit posted up, are those wires all in my car or is it what I need to get??? And what about this wire harnass??? I gotta get a new one??? Sorry for askin these nOOb questions. And how hard is it to install and one last question, where did y'all place ur antenna for the navi??? Wheres the BEST place to hide it or place it and still get GREAT signal?
Thanx again
Posted Apr 14, 2007 · 13:23 UTC#5
the wires i gave are the ones in your factory radio harness. the harness cntrylvr79 gave will plug into that harness in the car. then you just match the colors to your avi, with the exception of the vss and reverse, you have to hardwire them. its not difficult at all. put antenna on dash near windshield. it wont look bad, and will work fine
Posted Apr 14, 2007 · 13:29 UTC#6
MisFit thanks again. Since I been on this forum I see u always a good helpin person. Shoooot u should be awarded "Helper Of The Year" on here. Hey MisFit is it okay if I add u on AIM???
Posted Apr 14, 2007 · 13:34 UTC#7
theres plenty of real helpful people here, but thanks. i probably wont know who you are on aim, and just ignore it . just hit me on here, if i'm on aol i'll get notified right away anyway. its just as fast.
Posted Apr 14, 2007 · 13:47 UTC#8
I added you and YES there are A LOT of other helpers out there. Bout time you find people who are willin to help one another out without attitude...
But back to bidness, umm since this is goin to be my first time installin a navi system in my car on my own, what should I look out for??? Reason why Im doin this is cause I wanna learn on how to do a clean install. I purchased the Metra 99-7865 already. Looks like Im a have to cut the middle out. What else is need. And thanks a million.
Posted Apr 14, 2007 · 13:53 UTC#9
your biggest challenge as a first timer is going to be removing the factory radio. Honda seems to think their radios are made of gold or something, and make you take everything apart to get it out. do not try to pry it out. there are hidden screws you need to remove first. dont remember off the top of my head without looking at it, they change from year to year. just poke sround and dont just go yanking shit
Posted Apr 14, 2007 · 14:03 UTC#10
I already have an aftermarket system in my care. And do Ii NEED to get the Wiring Harness? "harness 70-1721"
Posted Apr 14, 2007 · 14:08 UTC#11
if you already have an aftermarket radio you may already have the metra harness in there
Posted Apr 14, 2007 · 15:38 UTC#12
Thanks MisFit. im a try and do this and post up some pix. I'll keep u posted and thanks for ur help.
Posted Apr 14, 2007 · 22:09 UTC#13
Factory Amp Turn-on
Power Antenna
Correct me if Im wrong but isn't it like this for the 2001-2005 Civic(no reverb)
12v Ignition/Acc... Red
12v Batt/Memory... Yellow
Ground ................ Black*
Powew Antenna..... Blue
Amp Turn-On........ Blue/White
Amp Ground......... Black/White
Illumination.......... Orange
Dimmer............... Orange/White
Speakers
RF(+)..... Gray
RF(-)...... Gray/Black
LF(+)...... White
LF(-)....... White/Black
RR(+)..... Violet
RR(-)...... Violet/Black
LR(+)...... Green
LR(-)....... Green/Black
And it also indicates that when a Black wire is not present, ground radio to vehicle chassis. All colors may not be present on all leads due to manufacturer's specifications.
Posted Apr 14, 2007 · 23:18 UTC#14
Those are the color codes for after market harness. All you have to do is match the wire colors from the avic harness to the metra harness. As far as how to take the radio out, this will help with that one.
http://www.metraonline.com/_assets/manu ... 9-7899.pdf
on a side note. Hey JasonH how about a new title for Misfit there.
Posted Apr 15, 2007 · 00:22 UTC#15
Sorry for askin a nOOb question again but do I have to buy the Metra Harness? What do I need 2 do now?
Posted Apr 15, 2007 · 00:24 UTC#16
Not if you already have one from the radio that's lready installed into your car.
Posted Apr 15, 2007 · 00:28 UTC#17
Well I got an aftermarket Apline head unit in it now but I did not install it but chances are I should have one correct?
Posted Apr 15, 2007 · 00:32 UTC#18
Yeah, all you'll have to do is cut the alpine end off and connect the avic end to it. If you're confucsed, when you're ready to do the install, snap a couple pics of the harness I'm sure one of us will be able to walk you through the install.
Posted Apr 15, 2007 · 00:35 UTC#19
dont be funny Josh
Posted Apr 15, 2007 · 00:38 UTC#20
DAMN cntrylv79, as soon as u said "CUT" u have me scared as bank teller wit a gun in her face. Im a have to cut the end off and rewire the colors to the matchin colors on the AVIC??? And thanks a lot will be postin pix when I start it.
Posted Apr 15, 2007 · 04:43 UTC#21
Relax. I'll try this with ascii.
Here's what you'll have when you take out the alpine radio that's currently installed in the car.
(Alpine)---------------------------(honda)
So what you want to do is cut it at the connectors that were used to put the 2 together. ( The X)
(Alpine)-------------X--------------(honda)
Now you can get rid of the Alpine side of that. Final step is to take the harness tha tcame with the avic and splice it into the honda plug you have. Remember match the wire colors that's all.
Posted Apr 15, 2007 · 04:44 UTC#22
dont be funny Josh
Why not, I can be just as funny as I can be a prick.
