WEll you can get it at the pcm, the same color.
The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud.
On gas models, the VSS wire is in the green plug, pin 50.
On diesel models, the VSS wire is in the black 58 pin plug, pin 42.
Never had a problem with te dozen or so I've done in the last few months. If those don't work you can get the new version of the metra gmos01. That gives you reverse, vss, parking brake, and illumination right at the radio harness.
