iPod's video wont come up on D3 & question on speed sens
By Rockybalboa · Apr 16, 2007in Problems/Troubleshooting💬 11 posts👁️ 1,635 views
Posted Apr 16, 2007 · 15:37 UTC#1
Hey guys...have a little bit of a problem. Everything works perfect with the D3, bypassed it correctly. iPod's music works, but for video's it only plays the audio and not the video. I am using the Pioneer CD-i200. Any idea's??
Also i did not install the speed sensor, which makes the "3d calibration" unusable. I was seeing what you guys thought about this feature and what exactly it does, and if you think its worth that i install the sensor.
Thanks in advance!
Posted Apr 16, 2007 · 15:58 UTC#2
well, installing the sensor helps regardless
the manual states that if u have a video problem to try shutting off ipod charging
Posted Apr 16, 2007 · 20:46 UTC#3
For the iPod video problem:
On the iPod, enable the "TV out" setting. That will enable the video out via dock connector. I doubt it's the charging setting but who knows. :)
Posted Apr 16, 2007 · 22:51 UTC#4
I agree with this tip, I think this is your problem
Posted Apr 16, 2007 · 23:59 UTC#5
for giggles where is this option? i have the 30gb video
Posted Apr 17, 2007 · 01:26 UTC#6
Yea, it was the TV Out Option...thanks a lot!
Goto video ->video settings, and its right there
Posted Apr 17, 2007 · 03:01 UTC#7
Glad we could help. 8)
Posted Apr 17, 2007 · 03:10 UTC#8
does this work on the D2 as well or only for the D3?
Posted Apr 17, 2007 · 04:03 UTC#9
Only the D3
Posted Apr 22, 2007 · 03:52 UTC#10
is it normal for the Ipod video quality to be noticeably lesser when the output is on the D3? Meaning..the video on the Ipod is almost crystal clear. The same video outputted to the D3 is just average. Much less color clarity/detail.
DVD's directly into the D3 show up perfect. And yes, the Ipod cable is unkinked and connected firmly.
Posted Apr 22, 2007 · 04:00 UTC#11
Yes it's normal. Just like picture on a small tv looks good, but put same picture on a big screen and it starts to look bad.
