Hi all,
I had some issues with the D3 when I first installed it (loose constant wire connection)... After I got everything fixed, I discovered the battery was dead... ![]()
After jumping the car, everything seemed fine as far as I could tell...
I have "tested" the car battery by using a voltmeter between the positive and negative battery terminals...
Typical readings after installing the D3 is around 12.3 to 12.5...
The car sat overnight and I tested it this morning and it was 12.37...
Question:
1) Is this the proper way to test and see if something is draining my battery???
2) Do these readings that I am getting sound correct???
3) Since you get 14v while the car is running, is it true that the battery will "level off" to around 12v after the car is off??? Or, is this not true???
Just trying to be sure the dead battery was due to using ACC all day long and having the doors open and all that stuff... And, not due to mis-wire...
Thanks,
Mark
