Alright heres the deal. I'm gonna be pulling out my D3 to redo some of my wiring. But the thing is i used "splice connectors" to tap into my stock amp turn on wire and my VSS wire. I'm gonna have to remove these taps to pull the metra and pioneer harness out of my car.
The only thing i'm worried about is when i remove the taps are'nt my factory wires gonna be barely holding together since they were crimped/cut by the splice connectors..? i'm gonna be putting these splice connectors back onto the stock wiring once i'm done redoing my connections from the pioneer harness to the metra harness. will the splice connectors be able to once again splice into the same spot on the stock wiring were they where?
i'm worried that i'm gonna have to solder my stock wire to back together after removing the splice connector... then once again splice into a new spot on the stock wire when i'm ready to put the D3 back in. I wanted to avoid hacking up my factory wiring as much as possible...
