flash memory
By cs98xj · Jun 13, 2006in Hacks/Mods💬 7 posts👁️ 2,406 views
Posted Jun 13, 2006 · 17:12 UTC#1
i want to convert back to the 40 series software on an n1, from the updated 50. I have heard that the flash memory can be removed and reinserted to be able to reload the older software, is this correct and has anyone done this before. if so what is the procedure for doing so? Thanks.
Posted Jun 13, 2006 · 23:19 UTC#2
you will need the pioneer cd-r11 remote remote which is discontinued or you can use the CXB7426 remote which took the place of the cd-r11 to input the password. i have the step by step walkthrough if you have those remotes.
Posted Jun 13, 2006 · 23:22 UTC#3
my bads, that was me, i logged in as a guest
Posted Jun 13, 2006 · 23:37 UTC#4
You won't need the remote.. Read the posts..
BAND button = BACK in the service menu
POS button = NAVI button in service menu
The password doesn't require remote either. It is done on the left joystick
UP, UP, DOWN, DOWN, ENTER (push in)
Posted Jun 13, 2006 · 23:52 UTC#5
no way, i bought the remote for nothing?? time to return!! thanx for the info!
Posted Jun 14, 2006 · 14:45 UTC#6
sweet man,,, can you send me the step by step to do so?
Posted Jun 21, 2006 · 18:44 UTC#7
Check on eBay for item 9744807559 or other irems from this man.
