AVIC-D3 Shutdown/Power Problem
By WarMachineXX · Apr 17, 2007in Problems/Troubleshooting💬 3 posts👁️ 733 views
Posted Apr 17, 2007 · 00:05 UTC#1
I have a AVIC-D3 which shuts down whenever My car is using excessive power. According to my scan gauge the Voltage never dips below 11V but the AVIC-D3 shows only 9V.
Any suggestion to clean up the power signal or is it possible the unit is defective?
Posted Apr 17, 2007 · 00:13 UTC#2
Is this with the engine running? If so then you have a problem with the cars charging system.
Posted Apr 17, 2007 · 01:51 UTC#3
Actually It was fixed with grounding. I reran the ground & got the +2 Volts Back.
