Enjoy!
pwgpe-qcph2-z1hk5
Enjoy!
pwgpe-qcph2-z1hk5
"Sorry, the offer code you entered is not valid. Please check the code and try again. Gift card numbers should be entered in Checkout."
See http://www.avic411.com/forum/viewtopic.php?t=4974&postdays=0&postorder=asc&start=150 for more referral codes.
If you need a code:
pe7ar-538s2-w5387
And if you need help with the bypass, check my flash gallery below
ok, I must be missing something here, do I enter it where it says "Special offer or catalog code?" or later on?
Place the order, then call a crutchfield rep and ask them to apply the code.
The "special code" is only for the 15% off code. Once you place the order, call them up and give them my code and they'll give you another $20 off.
OR, you can just call Crutchfield and give them all the info and let them put it all in (that's what I did). Never hurts to speak to someone. ![]()
Crutchfield Referral Code:
pd6r6-yhc2w-9zsqg
here's a $20 off code
p0ras-4wwif-q55wx
This one hasn't been used yet: p23fp-80j39-i2du5
Here's another...
P1HHI-0B042-CW2I3
One more...
p5tvc-7ysdz-656iv
got another code...
p0ras-4wwif-q55wx
Remember you have to call in the order to Crutchfield to use this code
PM me if you use it so I can take it down afterward...
And another! ![]()
