I used the can bus adapter to install my d3. Do you guys use that ground or ground the radio to something better.
Posted Apr 17, 2007 · 04:59 UTC#1
i used the ground on my stock harness
If there is a ground wire on your harness, you could use that just fine.
You could also find something metal to screw the ground spade connector to.
make sure to remove any paint/clear off the metal u are attaching it to... if it doesnt touch bare metal you will have a crappy ground
Thanks scrupul0us.
There shouldn't be much (if any) paint back there. But if there is, scrape it off! You want full metal on metal contact. ![]()
