D3 with Aftermarket Sub and Amp?
By BotoBoi808 · Apr 18, 2007in Problems/Troubleshooting💬 12 posts👁️ 1,807 views
Posted Apr 18, 2007 · 01:40 UTC#1
I installed a D3 in my 07 Civic Si. I hooked up an aftermarket sub and amp to the HU. I used the Non-Fading output and the remote turn on. I also did the bypass. The bypass works fine, but for some reason there is minimal sound coming from my sub. When I undid the bypass (removed and placed the mute wire in it's original position and ungrounded mute wire) my sub worked just fine. Has anyone ran into this problem?
Posted Apr 18, 2007 · 01:55 UTC#2
is the sub woofer output turned on on the deck?
Menu -> AV Menu -> Sound -> Subwoofer
is your sub amp turned up?
Posted Apr 18, 2007 · 01:57 UTC#3
Yes and Yes
Posted Apr 18, 2007 · 04:08 UTC#4
hey small boto :lol: i had the same problem but i found out that my rca wire was messed up. I also had a ground problem with the amp i had.. i don't know if this will help but information wont hurt any one right? But also check out the setting on the deck... i had to play with the eq because my sub were clipping alot .
Posted Apr 18, 2007 · 04:22 UTC#5
Gotta be from Hawaii! :D I get one hammah 4 u brah! Nah. I tried three different kinds of RCA's, all with the same result. Checked the grounds and they was all good. I played with with every sound mechanism on the HU with no positive results. When I put the mute wire back to the original spot though, everything was good.
Posted Apr 18, 2007 · 11:45 UTC#6
when you move the mute wire back (removing the bypass) are you hooking it up to anything? if so, what
Posted Apr 18, 2007 · 16:42 UTC#7
Nope. I just let it hang there like normal.
Posted Apr 18, 2007 · 17:03 UTC#8
well that makes no sense to me then...
i mean i guess u could try amping up the level to the woofer on the woofer menu
what amp are u using for your subs?
Posted Apr 18, 2007 · 17:25 UTC#9
I played with every sound setting on the HU, including the subwoofer and non fading level settings. My point is I have the D3 hooked up the way it's supposed to be hooked up and it works fine. When I do the bypass, none of the preout's work, well, they do, but there is very little sound coming from the sub. I have a RE Audio 12.1 Mono Class D for my RE Audio SE 12" Sub.
Posted Apr 18, 2007 · 17:49 UTC#10
I would try grounding the bypass to a seperate ground than the radio. It sounds like the additional ground is pulling away from the other grounds.
Posted Apr 18, 2007 · 17:52 UTC#11
The bypass meaning the mute wire when it's in the modified pin slot?
Posted Apr 18, 2007 · 17:56 UTC#12
Yes, ground it to a metal point in the dash somewhere. It sounds like your grounding in insufficient when the bypass is included. This should provide the necessary grounding without taking away from anything else.
