Parrot 3200 Bluetooth
By JHG120 · Apr 18, 2007in General💬 18 posts👁️ 2,598 views
Posted Apr 18, 2007 · 20:14 UTC#1
I have a D2 and a Cingular CG300 BT phone.
I have read good reviews on the Parrot 3200, and since the D2 doesn't work so well with the Pioneer BT, I'm thinking about the 3200.
Has anyone used or seen one operate?
Also, I've read that since the navi voice guidance will mute the sound when the lady talks, that the 3200 will not be able to hook into the mute wire. My mute wire is not being used on my harness, so can I just hook into that wire and have both mute functions work properly??
I also saw that you have to buy seperate harness' for the Parrot, so will these new harness' that will hook into the middle of my factory and the avic screw anything up?
Thanks for the help fellas.
Posted Apr 18, 2007 · 21:15 UTC#2
they work fine, as long as your not using an external amplifier the wiring is not a problem. i install these all the time, nice piece
Posted Apr 18, 2007 · 21:18 UTC#3
Thanks. So the mute function will actually work for both voice guidance and incoming/outgoing calls?
Thanks again.
Posted Apr 18, 2007 · 21:20 UTC#4
Yup nice little toys. Btw misfit they work with external amps, just takes a bit of creativity in the wiring. How else is the one I bought from you gonna work. Well in 6 months when I get around to putting it in and all that glasswork.
Posted Apr 18, 2007 · 21:54 UTC#5
dont know if i'd want to run all that power through that little box
Posted Apr 18, 2007 · 22:34 UTC#6
You don't have to. It requires a couple relays and use of those line output wires. I'll grab the diagram from work tomorrow.
Posted Apr 19, 2007 · 00:05 UTC#7
Hey guys, but mostly Misfit because you've installed a few of these...
I just talked with Crutchfield, and they said that there isn't a harness that I need to get to hook the Parrot 3200 to my D2. I've read some reviews where people said they did buy extra harness'. Is this true, or can I just use what I have so far.
2005 Nissan Altima
Avic D2
Thanks!!!
Posted Apr 19, 2007 · 00:13 UTC#8
it intercepts what you already have. one end goes to your avic harness, the other end goes to your metra harness. you just color match
Posted Apr 19, 2007 · 00:17 UTC#9
I'm sorry to ask, but is that a yes there is another harness. Sry.
If so, any idea where to pick one up...Best Buy, Circuit City....online somewhere?
Do you possibly know where to find it?
That is if the answer was yes.
Thanks again bud.
Posted Apr 19, 2007 · 00:19 UTC#10
do you have a metra harness for your install?
Posted Apr 19, 2007 · 00:24 UTC#12
yes, thats it. the parrot gets wired between that harness and your avic harness. you dont need anything else.
just out of curiosity, what are you paying for the parrot?
Posted Apr 19, 2007 · 00:28 UTC#13
Cool. The best I've seen is....they're all brand new btw:
Amazon: $164.43
Ebay: $169.99 Buy it Now
-tons more on Ebay for same price
Crutchfield: $249.99
So either Amazon or Ebay.
Any other suggestions?
Posted Apr 19, 2007 · 00:31 UTC#14
no, thats not bad, just watch who you buy from
Posted Apr 19, 2007 · 00:32 UTC#15
Cool, thx again for all the help.
Lastly, I have a Cingular LG CG300, rather cheap phone, any ideas if it will work. It has Bluetooth, duh. lol.
http://www.mobiledia.com/phones/lg/cg300.html
Posted Apr 19, 2007 · 00:34 UTC#16
it should
Posted Apr 19, 2007 · 00:36 UTC#17
Cool. I'll order. I'll let you know how install goes, especially if I have any questions. :D
Many thanks.
Posted Dec 11, 2007 · 19:59 UTC#18
Sorry to jump the thread.
So I have the Infinity G35 with the Avic D1 already installed. So am buying the Crutchfield Bluetooth harness for OEM Infiniti and you just use the existing Metra harness for my AVIC and connect the Bluetooth harness between the connection now?
