Reverse Wire for 2007 Camry SE
By Striker317 · Apr 19, 2007in Vehicle Specific Wiring💬 7 posts👁️ 3,952 views
Posted Apr 19, 2007 · 15:02 UTC#1
Hi
I was able to locate the VSS wire for the 2007 Camry SE, but I couldn't find the reverse wire. I currently don't have it connected, but since I'm going to go back into the car to clean up some loose ends this weekend, I figure I might as well attach it and do it right.
Is it the same as the 2005 Camry (which someone posted the answer to below) or is it somewhere else? Also, what does DKP stand for?
Thanks for any help you can provide
Posted Apr 19, 2007 · 15:14 UTC#2
If you don't have a backup camera there isn't really any point in hooking up the reverse wire.
Posted Apr 19, 2007 · 17:56 UTC#3
Reverse Light red + driver kick, 17 pin plug, pin 9
dkp = driver's kick panel
Posted Apr 19, 2007 · 18:40 UTC#4
Hi vicn77
Thanks for your reply.
Before you posted, I happened to find this doc re: the reverse wire.
It says that it should be a grey coloured cable
http://www.oemvalue.com/2007camry/2.jpg
Just wanted to confirm which one is correct.
Thanks again
Posted Apr 19, 2007 · 23:46 UTC#5
Both are right, you're talking about getting it on opposite sides of the vehicle
Posted Apr 22, 2007 · 03:36 UTC#6
Thanks a lot.
Found it successfully!
Posted Jul 01, 2007 · 04:15 UTC#7
Hi
/quote]
I did some search in this forum, but where is the VSS wire for a 2007 camry ? Thanks for your help.
