how high should the speed pulse signal go?
By bryancx94 · Apr 19, 2007in Problems/Troubleshooting💬 8 posts👁️ 1,571 views
Posted Apr 19, 2007 · 15:45 UTC#1
I gotz an avic-D3
When I am stopped it's at 0 then as I accelerate up to about 10mph it hits around 100, as I go faster it goes higher, as high as 400 and the graph is all the way up. If i leave this screen open I eventually get irregualr speed pulse.
I already tried resetting my unit, the vehicle dyanmics do not work either i get, function not avaiable, and i have driven about 500 miles. O yes i also get the shop demo screen loading when i turn my car on. I have tried numerous resets. Is this all related to the VSS wire being on the wrong wire? What's the average climb on the speed pulse?
Posted Apr 19, 2007 · 15:55 UTC#2
it varies from car to car, as long as it goes up with acceleration you should be ok
Posted Apr 19, 2007 · 23:41 UTC#3
year/make/model of the vehicle and where you tapped vss would be helpful.
Posted Apr 19, 2007 · 23:47 UTC#4
On an '02 Audi it looks like reading is 1/100 motor RPM.
Posted Apr 20, 2007 · 13:27 UTC#5
yeah sorry.. 2005 chevy colorado ext cab. I tapped the yellow/black wire on the PCM. There was two of them, i tapped one of them and started getting signal when i accelerated so I assumed this was correct.
Posted Apr 20, 2007 · 17:07 UTC#6
Try tapping the other one them. Assumption is the mother of all fu&kups
Posted Apr 23, 2007 · 12:19 UTC#7
Well i switched to the other wire, no dice. I just disconnected it for now. The other really annoying thing is still the DEMO mode screen. After removing the VSS wire, i reset the unit once again. No luck. Anyone know how to correct this?
Posted May 31, 2007 · 01:47 UTC#8
I'm Getting the same problem on a 2007 Chevy Colorado,
Same Demo screen on startup, and on one wire i get very high numbers, the other is nothing...
