Ford Ex OBD II
By PaisanNYC · Apr 20, 2007in Vehicle Specific Wiring💬 9 posts👁️ 1,485 views
Posted Apr 20, 2007 · 09:56 UTC#1
I am receiving a new Equus 3100 code reader, and was hoping someone would know where the OBDII plug was on a 97 Ford Explorer? Im sure its in an obvious spot, but it's 5AM, and I am at work already. Too dark to go looking around under the dash. :) Thanks!
Posted Apr 20, 2007 · 11:35 UTC#2
usually under the dash on either the left or right side of the steering column
Posted Apr 20, 2007 · 13:07 UTC#3
if i remember correctly theres a littleplastic pop out at the bottom of the drivers side dash, but if i'm thinking of the wrong year then its right behind the dash panel at the bottom
Posted Apr 20, 2007 · 17:09 UTC#4
thanks guys. I am doing another 13 hour day at work, so I will try it when I get off. Thanks!!
Posted Apr 20, 2007 · 17:11 UTC#5
Left side of the dash by the door facing down.
Posted Apr 20, 2007 · 21:42 UTC#6
it was actually right under the dash in the middle under the steering column facing outward. Sorry cntry :(
Posted Apr 20, 2007 · 23:50 UTC#7
Ahh that's what I get for going off my memory. Hell my brain age is 87 so I guess that'll tell ya something...
Posted Apr 20, 2007 · 23:54 UTC#8
you sure it wasnt an empty bottle of JD again? LOL
I have some problems tho :( Thing tells me I have two problems, "Catalyst System Efficiency Below Threshold" and " Camshaft Position A Circuit". I REFUSE to spend any more $$$ on this 10 yr old jalopy! lol
Posted Apr 20, 2007 · 23:56 UTC#9
The first one sounds like a bad cat or 02 sensor. The second sounds like a problem with the camshaft position sensor.
