N1 to N3 upgrade help
By airm45 · Apr 20, 2007in Hacks/Mods💬 4 posts👁️ 1,918 views
Posted Apr 20, 2007 · 12:09 UTC#1
Hey guys, i have an N1, and am upgrading to an N3 brain. My question is (since i didn't install my N1) when I get the N3 brain, is the sticker where you flip the switch on the hideaway brain, or is it on the n3's headunit? and is the green wire on the headunit or the brain?
Posted Apr 20, 2007 · 17:08 UTC#2
The bypass switch for the N3 is on the headunit itself, not the brain. I am not sure how the bypass works on the N1 with an N3 brain, but on the N1 itself all you needed to do was bypass the green parking brake wire, which is located on the harness that plugs into the headunit (not the brain).
Posted Apr 21, 2007 · 00:29 UTC#3
currently my N1 is bypassed, so if I just get the N3 brain, I should be fine right?
Posted Apr 21, 2007 · 17:03 UTC#4
not if you only have the parking brake wire grounded...the unit must be opened and soldered
