Holy cow, i have a tdi jetta and i did the bluetooth software update, and it still sounds HORRIBLE, no clue why? i think the tdi motor vibrates too much. anyone else have a problem with a diesel motor?
Where is your mic mounted? Make sure there is an inch or two of clearance behind it for the noise cancellation to work, and make sure its not right against glass
is in the flip down sunglass case in the roof, if i am parked with the motor off sounds good i guess?
i just called in for it last friday april 20th. kinda anxious to see what/if there are any improvements to it....i have a 2004 infiniti G35 coupe and i have the mic in the center between the 2 visors....
