avic d3 static at all volumes
By jwdomino · Apr 24, 2007in Problems/Troubleshooting💬 4 posts👁️ 836 views
Posted Apr 24, 2007 · 00:35 UTC#1
I have a 2004 GTP and have the d3 recently installed( 2 days ago)
MY car had the monsoon system, so i needed to buy the schoche (wrong spelling) "chime/alert" adapter. so now since then I have a low level "hiss" or static on any input or function with the deck off or on. I have checked all grounds, all good, checked the rca level for proper grounding. all wiring wise is good.
Does with car running or not. I assume it has to do with the adapter.
I am contemplating just swapping the factory amp out unless there is a known issue I have not found.
so to summarize what I have checked:
ground is good, one connection at bare metal in chassis
no uncapped rca's
all connections good
btw the "mute" wire mod works great!
any ideas would be helpful
Posted Apr 25, 2007 · 01:29 UTC#2
Did you bypass the monsoon amp? If not that's the reason. That "special" harness you bought doesn't do anything in regards to the monsoon amp. That just retains the door chimes, retained accessory for the radio, and off star if you have it.
Posted Apr 25, 2007 · 02:03 UTC#3
so the monsoon amp needs to be bypassed?
it come with rca's to plug from my deck to the factory wiring.
Posted Apr 25, 2007 · 02:06 UTC#4
Yes it does.
