I did a search for ERROR-12 but I found nothing.
ERROR-12 is the error message I get when I try and put a Dvd in my D2.
On my source menu with a Dvd in the only ones lit up are just radio and CD.
Does anyone know why it says ERROR-12?
If you check the manual, Error-12 is a dirty disk. And by the way, the D2 doesn't play DVDs
Really is says it does... Well it says DVD on the thing.
I was messing around and under the Audio option i went to setup then AV-Input and it was set to off so then i could change it to either Video or M-DvD so i put it on M-DVD then when i went back to AV screen it was just a blank screen...
It says DVD-rom, thats the navigation disk. If you want to watch movies, you have to buy a seperate DVD player and run it into the A/V input
So like if I put a ps2 in there? I could watch them through the ps2 right?
If you have done the bypass
Yet another case of RFTM with emphasis on the R.
