Need honesty
By dbird35 · Apr 25, 2007in General💬 3 posts👁️ 875 views
Posted Apr 25, 2007 · 01:39 UTC#1
Hey guys, I'm located in Miami and I'm tring to get my Z2 installed but I'm not sure how much is a reasonable price for install. I have an 02 cadillac EXT, but the factory is not a double din its a din and half.
Posted Apr 25, 2007 · 01:42 UTC#2
It has been done. Either way you go, it's either going to cost a nice chunk in labor or a nice chunk in parts. The dash from an 03 can be sourced, but the ac controls and some of the sub dash must be modded. Or the oe dash can be modded and the ac controls moved. Not something I recommend for the novice.
Posted Apr 26, 2007 · 01:09 UTC#3
basically what the other reply says. id try to source an 03 dash. or, if you are a IDY'r go ahead and try to cut your dash now. if you mess up, you will probably still want to use the 03 dash anyway. rough estimate to cut the dash at a shop i would say about 165 bucks. just keep in mind that any shop that attempts this will make you sign a waiver of liabilty. good luck.
