2004 Ford Expedition
By jwconnell · Apr 25, 2007in Vehicle Specific Wiring💬 8 posts👁️ 3,956 views
Posted Apr 25, 2007 · 05:44 UTC#1
Hello everyone. I have about decided to install a D3 into my 2004 Expedition. I will be replacing Ford's premium radio with Nav, rear seat DVD. The radio has five or six various connectors. I assume for speakers, subwoofer, nav antenna, steering wheel controls, rear seat controls, etc. Does anyone know where I can find documentation on all of these connectors as well as a set of prewired connectors that I can use to patch from the wire harness to the wiring harness for the D3? Additionally, I think that I can make the steering wheel controls work with a PAC-PC. I could probably use a PAC-PC for the rear seat controls as well, but is there some way to connect the two together before connecting to the D3? Thanks in advance for your help.
Posted Apr 25, 2007 · 11:47 UTC#2
pac swi-ps for steering controls
metra 70-5521 for radio and subwoofer
metra 70-5520av for rear dvd
Posted Apr 30, 2007 · 18:54 UTC#3
Thanks for your help MisFit. I found a lot of info on Ford radios, but nothing on the model that was in my Expedition. With a volt meter and some trial and error, I think I have figured out most of the connections (lights, reverse, speakers, power, etc.) on the back of the radio.
A few more questions if you don't mind... If I don't have a rear view camera, do I need to hook up the reverse wire... or can I disable the rear camera switching? The subwoofer connects to the radio with a single connector containing four wires. I am assuming that two would be power and ground -- the other two audio??? I can discover power and ground. Any way to figure out polarity on the audio?
Posted Apr 30, 2007 · 19:00 UTC#4
I knew that I would forget a question...
The wire for "lighting" in the radio harness must come from the dash lighting. The voltage drops as the dash lights are dimmed. Will this work OK or do I need to find a wire that is 12V when the lights are on?
Thanks again.
Posted Apr 30, 2007 · 23:48 UTC#5
if you get the metra harness i mentioned you wont need to figure out the wiring. you just match the colors. no you dont reverse if you dont have a camera. fords have an illumination and a dimmer wire, you want the one that goes 12v when the lights are on but does not dim. when you get the matra harness there is a plug for that subwoofer harness and you will see what is what. you just need to put a 3k ohm resistor between the blue/white wire from the avic and the one on the metra plug to keep the amp from "popping' when it turns on
Posted Jun 21, 2007 · 20:57 UTC#6
misfit, thanks for all your knowledge, i have a 2005 expedition and just received my metra 70-5522 harness to connect my factory sub to my avic d1, but where do i connect the two cable coming from the harness??? thanks in advance
Posted Jun 21, 2007 · 23:34 UTC#7
to the sub outputs from the avic
Posted Jun 23, 2007 · 15:03 UTC#8
not the rca's im talking about the color coded wires??
