Mazda3 Mazdaspeed3 Wheel Speed Sensor Wire VSS?
By maratik999 · Apr 25, 2007in Vehicle Specific Wiring💬 4 posts👁️ 1,996 views
Posted Apr 25, 2007 · 16:57 UTC#1
Please help with the location of the Wheel Speed Sensor wire so that i may tap into that for D3 install. Based on the information available, there is no VSS wire on the new Mazda3. So what is the best alternative? Thanks so much in advance.
Posted Apr 26, 2007 · 02:36 UTC#2
there is none in your car. set it to learn mode, it will work fine
Posted Apr 26, 2007 · 05:53 UTC#3
Aight, sounds good.
Posted May 24, 2007 · 14:48 UTC#4
there is a vss for this car comes right off of the ecu if i remember correctly it is a white wire with blue stripe 05 model. If it is the same for any other year i do not know but whati have been told is that they are all the same except for 07
