Illumination Wire for 2002 Saab 9-5 Aero
By chazmink · Apr 26, 2007in Vehicle Specific Wiring💬 7 posts👁️ 1,821 views
Posted Apr 26, 2007 · 18:36 UTC#1
The Saab 9-5 radio harness does not have an illumination wire. The car has daytime running lights. Any suggestions on where to connect the D3 illumination line so that the day-night feature is functional would be appreciated.
Thanks.
Posted Apr 27, 2007 · 01:48 UTC#2
Headlight switch.
Posted Apr 27, 2007 · 01:53 UTC#3
I appreciate the response, cntrylvr. That would probably work if I didn't leave the lights in the autosense mode. i imagine a photocell trips a relay somewhere but I don't have a decent wiring diagram for the car. I suppose I could start using the headlight switch but prefer not too. Amazing how lazy I've become. All three of our cars have automatic headlights.
Thanks, again.
Charlie
Posted Apr 27, 2007 · 01:56 UTC#4
Sounds like you're beat. Unless you wire up a separate switch.
Posted Apr 27, 2007 · 02:19 UTC#5
I knew that was an option but was hoping to find an alternative.
Thanks, again.
Posted Apr 27, 2007 · 23:36 UTC#6
What about tapping into the actual headlight wire itself. Then it'll only switch over when the headlights turn on. The down side is you'd have to run a wire from your headlight back into the car.
Posted Apr 27, 2007 · 23:51 UTC#7
That's not a bad idea. I'll have a look tomorrow,
