VSS Vehicle Speed Sensor Cable in Hyundai Tiburon 2003
By avicer · Apr 27, 2007in General💬 5 posts👁️ 1,853 views
Posted Apr 27, 2007 · 03:51 UTC#1
does anyone know where i can find the speed sensor cable in this car? been googling and searching forums, but no luck... thanks.
Posted Apr 27, 2007 · 11:53 UTC#2
Speed Sense brown data link connector, pin 11
The data link connector is under the driver side dash in the fuse box opening
Posted Apr 27, 2007 · 14:57 UTC#3
thanks misfit!
do you know by any chance how i would "tap" into that wire? should i just split the cable and connect to avic?
Posted Apr 27, 2007 · 15:37 UTC#4
The D3 unit comes with all the parts. You should not have to cut any existing VSS cable at all.
There should be a pink clip thingy. That's what you use (see the instructions).
Posted Apr 27, 2007 · 16:17 UTC#5
i have seen that clip thing. so that clip goes directly into the vss cable on the car side? i have not seen the vss cable yet, so i don't know what it looks like.
