AVH4000NEX questions/issues
By Dougw133 · Nov 23, 2014in NEX Series💬 4 posts👁️ 1,316 views
Posted Nov 23, 2014 · 20:52 UTC#1
Two things.
1- Back up camera. Very confusing read in the manual on the modes. I currently have a camera installed. I have it hard wired to battery power and is triggered on by a relay to my ign wire. I have been doing electrical for years. So basiacally turn the car on, relay trips and the camera has power. I really want to be able to simply toggle the camera on and off. I dont see any option to do it other than in the settings menu. When I do, the camera wants to stay on all the time and I have to hold MODE for 5 seconds to get back. Is there really no AV shortcut or something to toggle the camera view? I am going to hook up the purple wire to my reverse light trigger tomorrow.
2-SD card file sorting. I have a standard music library Artist-->Album-->Songs etc.. When I play all the unit starts them Alphabetically ALL SONGS. So basically when Im listening and want to take it off shuffle and just listen to that album, I cannot. It also does not allow me to skip backwards. This seems ridiculous. This is my first modern Pioneer unit in a long time. Is there no way to set sorting options? Artist, album, song track number and Alphabetically? I am using a 256gb SD card in NTFS.
Thanks in advance.
Posted Nov 25, 2014 · 13:13 UTC#2
holding the map button will turn the camera after that if you touch the screen it will toggle back the the regular screen or press the X on the camera screen to turn it off
Posted Nov 26, 2014 · 14:33 UTC#3
if your trying to turn on camera manually and with out going thru settings you could trigger reverse wire off head unit with a toggle switch,just diode it so it doesn't back feed to reverse lights
Posted Nov 30, 2014 · 06:23 UTC#4
Thanks for the replies. Got the reverse wired up, working well. Just can't believe there's no quick toggle button in the AV menu. I dont have a navi unit so there's no map button. Actually Im not suprised, this is pioneer we're talking about.
