I'm in the process of installing the Z1 on my 2006 Mustang. I am swapping out the Shaker 500. A few things I'm confused about:
1) Apparently the orange/white wire in the old Shaker harness is not the illumination/dimmer wire, and I actually need to splice into this by the light switch. Anyone know which wire I need on this?
2) Is there a way to tap into the VSS wire without going into the engine? The Shaker 500 has speed sensitive volume, so I've got to believe there's a line to that in the head unit area.
3) Does anyone know where the reverse light wire is without going all the way to the trunk?
Thanks a bunch!
Posted Jun 15, 2006 · 18:06 UTC#1
