2006 F-250 parking brake ground wire
By eghostrider · Apr 28, 2007in Hacks/Mods💬 7 posts👁️ 2,616 views
Posted Apr 28, 2007 · 06:22 UTC#1
Hello All,
I'm trying to ground the parking brake wire on my 2006 F-250, but I have located 3 green wires. I have a light green, med green, and dark green wire. Which one do I cut and ground? I'm afraid of screwing up my D-3 unit if I do the wrong one.
Posted Apr 28, 2007 · 12:17 UTC#2
You ground the one coming off the back of the d3.
Posted Apr 28, 2007 · 15:59 UTC#3
I know, but which color, there are several green wires.
Thanks,
Dave
Posted Apr 28, 2007 · 16:42 UTC#4
Thanks,
Dave
dude, if you dont know what the wires on the unit are, you really shouldnt be installing this yourself
Posted Apr 29, 2007 · 05:27 UTC#5
It was installed by the Audio store, I just want to bypass the parking brake. I'm just trying to figure out which wire to ground.
Thanks.
Posted May 03, 2007 · 10:32 UTC#6
Ok the Dark Green and the Dark Green with a black line is your Left Rear Speaker. The Light Green is the brake cable. the one you will need to Ground. Ground it to metal part of car and if there is paint scratch it off to get a better ground. Also I would recomend if you cut the wire you put black electrical tape on the other side (Side not grounded but cut) so it will not touch anything else and possibly cause problems.
Posted May 04, 2007 · 03:41 UTC#7
Thanks DSSHobby. I will try it, I sure appreciate it.
Egho
