Anybody in TN want to make some money
By flowtime · Apr 29, 2007in General💬 25 posts👁️ 3,880 views
Posted Apr 29, 2007 · 09:40 UTC#1
Hey guys I need some help installing D3 in my 07 Altima and I want to bypass the D3. I can't find anybody who knows what they are doing and I sure don't know. So if any body wants to make some extra cash let me know.
Posted Apr 30, 2007 · 00:54 UTC#2
Hey just to add to the above you don't have to be in TN if your in any of the surronding states I'll travel
Posted Apr 30, 2007 · 06:18 UTC#3
Where in TN? I live in Louisiana.
Posted Apr 30, 2007 · 06:19 UTC#4
I will be up there within 2 weeks
Posted Apr 30, 2007 · 16:22 UTC#5
i live in bowling green ky about 60 miles north from nashville i just installed a d2 in my mustang and did the navi bypass it works fine.
email me [email protected]
Posted Apr 30, 2007 · 16:52 UTC#6
I live in Middle TN about 30 miles out of Nashville in Murfreesboro
Posted Apr 30, 2007 · 18:35 UTC#7
I'd do it but that's about 4-5 hours from me. :/
Posted Apr 30, 2007 · 19:03 UTC#8
Necro if you know how to install a Z1 with the bypass i'll come to you
Posted Apr 30, 2007 · 20:21 UTC#9
Don't know much about the Z1 sir. Sorry.
Posted Apr 30, 2007 · 21:33 UTC#10
Ok.. The 07 Altima does have a dash kit yet so I to get the factory front trim and the trim is 9" so i was going to get the z1 because that would fit better, but if you know how to fill up the spaces I can get the D3
Posted May 01, 2007 · 00:35 UTC#11
The Z1 and D3 are both double din and take up the same space. The only difference (size wise) is the screen.
Posted May 01, 2007 · 02:46 UTC#12
I just got my D3 and I am ready for the install... from what I'm readiing it looks like it's too bad that misfit is in NJ cause he's doing a great job, but if there is anybody around TN that can do it let me know
Posted Jun 13, 2007 · 19:49 UTC#13
and btw i have bluetooth, backup camera, and ipod adapter
Posted Jun 13, 2007 · 20:40 UTC#14
99-7423 - dashkit, 40-NI12 - antenna adaptor, 70-7552 - harness. Those are the parts you'll need.
Posted Jun 13, 2007 · 21:02 UTC#15
can you buy any of that at any stores or do i have to order it all
Posted Jun 13, 2007 · 21:27 UTC#16
Dunno, none of the shops in my area have that stuff in stock. As far as ordering goes, you could check out www.installer.com
Posted Jun 13, 2007 · 21:38 UTC#17
that wireing harness makes it so i don't have to change out all my speakers because i have bose right?
Posted Jun 14, 2007 · 20:54 UTC#18
is the bluetooth adapter supposed to come with a mic
Posted Jun 14, 2007 · 21:02 UTC#19
No, the mic does not come with the blue tooth adapter. The mic comes with your head unit for voice command.
Posted Jun 14, 2007 · 22:45 UTC#20
Actually, if you are getting the D3, and you bought the BT that is compatible with the D3, then it does come with a mic that you need to mount in the car. If you have the Z1, it has a built in mic, and the compatible BT module that you bought for it does not need a mic.
Posted Jun 14, 2007 · 23:14 UTC#21
I have the D3 and I ordered the nd-bt1 and it doesn't have a mic with it. My car already has bluetooth so it has a mic in the car already could I just use that mic??
Posted Jun 15, 2007 · 00:49 UTC#22
No, and the nd-bt1 doesn't work with the d3. You need the cdbtb200.
Posted Jun 15, 2007 · 04:20 UTC#23
crap well i'm gonna have to exchange the one i have now..I am thinking about installing this thing myself just because all the places around here want to charge me like 350-400 to install it and they all say i have to change my speakers out because they are bose.
I have never done any car work like this on a car do you all think I should even try this?
Posted Jun 15, 2007 · 04:29 UTC#24
Me personally, i would rather have someone do it. 350-400 is not much considering they are (and hoping doing it right) right. Because if you screw up it may end up costing you more. My installer left some stuff not programmed right as far as the steering wheel controls, so i had to locate the module to see where he installed it and read manual to re-program it. Then i found out he didnt connect VSS wire so i had to do that myself as well. I had only done minor system installations like, equalizer, amp, stereo. I was not familiar with navi, back up camera and the like. Now i make more money and have less time so i rather had someone do it for me.
Again thats just how i feel. If you feel confident enough to do it, then go for it.
Posted Jun 15, 2007 · 05:13 UTC#25
ok so I defiantly want the bypass I've already changed the mute wire out.. what would i have to tell the installer to do to complete the bypass
