Anyone know the VSS & Reverse colors and location?
Speed Sense dk. green/white ECM
ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the VSS wire is at pin 3 in the connector labeled black. On the 4.8L, 5.3L, and 6.0L, the VSS wire is located in pin 50 of the red connector.
can also check the radio harness
Reverse Lights RED (+) ECU PIN13 PSC/ECU TO THE FAR RIGHT BEHIND GLOVE BOX
Speed Sense PURPLE (AC) ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 14 OF A 26 PIN PLUG
