Parrot Bluetooth with Avic D2?
By universal9gsm · Apr 30, 2007in General💬 16 posts👁️ 3,522 views
Posted Apr 30, 2007 · 03:34 UTC#1
Obviously Avic D2 cant have bluetooth so i was wonderinggg will a parrot bluetooth kit 3200 LS-Color work perfectly with Avic d2 because i heard parrot mutes ur radio when a call comes so u think that universal mute that parrot supplies mute avic d2?
let me know wha u guys think
http://www.sonicelectronix.com/item_788 ... 200LS.html
this is the link to the product
Posted Apr 30, 2007 · 03:52 UTC#2
why cant it? the bluetooth modules work, they are just very limited and quite frankly suck when used with the d2.
a parrot kit is a universal kit to be used with any vehicle.
Posted Apr 30, 2007 · 03:57 UTC#3
yea but i think when parrot bluetooth works with any car radio but i think its referring to OEM radio Avic d2 is not oem its after market so just wondering
Posted Apr 30, 2007 · 04:38 UTC#4
It mutes any radio, OEM or aftermarket. Should work great with a D2
Posted Apr 30, 2007 · 04:46 UTC#5
aite thanx
Posted May 02, 2007 · 01:11 UTC#6
it works great! i have the exact setup in my truck and love it. avic d2 with parrot 3200.
Posted May 02, 2007 · 02:10 UTC#7
can u confirm the radio mute and the phone call thru the car speakers and the call quality
Posted May 02, 2007 · 04:00 UTC#8
Yes please elaborate more... :)
Posted May 02, 2007 · 05:59 UTC#9
yes it mutes the radio and then runs the sound through all 4 speakers. sound quality is good...i can understand everything like i have the earpiece on. the parrot wires inbetween the stereo wires. meaning they have to be cut and run through the parrot module...if you have a volkswagen then its a direct plug in b/c theyre VW plugs on it. i just cut them off and wired them into my f150.
Posted May 24, 2007 · 16:35 UTC#10
when u say cutting the wires in between is there alot of modifications needed?
Posted May 24, 2007 · 17:13 UTC#11
not a lot of modification. just take the 8 speaker lead wires, cut them in half and wire in the parrot between them. the parrot has color coded wires (white, grey, purple, and green).
Posted May 27, 2007 · 20:09 UTC#12
Trust me guys, the Parrott is well worth the effort! MUCH BETTER than than the Bluetooth adapter on the Z1 anyways!
I installed one into the wife's car and wish I'd picked up 2 of them rather than just 1
Posted May 27, 2007 · 20:12 UTC#13
If you don't want to cut off the ends on the parrot harness you can pick up a 70-1784 and a 71-1784. Those plug into the parrot harness and will give you the raw ends needed.
Posted Jun 21, 2007 · 15:13 UTC#14
if you would rather just have a plug and play solution you can also check out http://www.parrotkits.com/index.html and you should be able to find what you are looking for. If you have any questions, just send an email. My experience is a reply usually within 24 hrs.
I hope this helps,
Yes the smoke is normal.... do you have an extinguisher?
Posted Jun 27, 2007 · 00:12 UTC#15
cntrylvr79 which exact one would work with my honda civic 01 and d2?
70-1784 or 71-1784 or did u mean both?
Posted Jun 27, 2007 · 00:25 UTC#16
Both.
