2005 Ford Five Hundred Limited VSS & Reverse wires
By abrose · May 01, 2007in Vehicle Specific Wiring💬 9 posts👁️ 3,755 views
Posted May 01, 2007 · 14:52 UTC#1
Hello Everyone,
This is my first post to this site and I must say that it is an awesome resource! Because of the good info on this site, I am going to purchase an AVIC-D3 for my 2005 Ford Five Hundred Limited. But before I buy, I want to make sure that my car does indeed have a VSS/Speed wire. Based off of reading the other info for Fords, I assume that the wire is gray/black wire in the harness, correct? Also, I need the location fo the reverse wire as well. Thanks guys for all of your help!
-Albert
Posted May 01, 2007 · 18:47 UTC#2
Reverse Light white/yellow + driver kick or SJB, conn. E, pin 18
FORD, FIVE HUNDRED, 2005, Reverse Light
The SJB (Smart Junction Box) is the fuse/relay box under the driver side dash.
I can't find a VSS wire for you though.
Posted May 02, 2007 · 17:09 UTC#3
Thanks a ton vicn77. Does anyone have any info about the VSS wire location? I really don't want to buy the D3 unless everything works properly. Thanks!
Posted May 02, 2007 · 20:42 UTC#4
that car does not have a vss wire. put it in learn mode, you'll be fine
Posted May 02, 2007 · 21:15 UTC#5
I have a D3 in my '06 Zephyr and the VSS is not needed. The NAV system is dead on with MPH and tracking.
Posted May 02, 2007 · 22:23 UTC#6
Thanks MisFit and naplesbill......your comments have easied my fears. Naplesbill, is your GPS antenna installed on the inside or outside of your car? I think I just might order my D3 this evening.... :)
Posted May 02, 2007 · 22:33 UTC#7
I have the GPS antenna on my dash and I get 5-6 bars most of the time.
Posted May 02, 2007 · 22:41 UTC#8
Excellent.....I was planning on doing the same with my 500. Thanks naplesbill. Now if I can only find a good deal on a D3....I hate that I miss the Crutchfield deal by a couple of days. Thanks again!
Posted May 03, 2007 · 00:24 UTC#9
what kind of deal you looking for? maybe i can help you out
