Red line in navigation?
By leo · May 01, 2007in General💬 16 posts👁️ 3,168 views
Posted May 01, 2007 · 15:29 UTC#1
The red line that the D3 plots on the nav map during use drives me crazy - i have searched around to try to get rid of this...is there any way at all? Its so annoying - why couldnt they put a side bar compass or arrow to show the direction of your location...the red line gets in the way of the map and is completly useless.
Posted May 01, 2007 · 16:49 UTC#2
its there, position tracking or something, i dont recall, but it can be removed. I actually wish that my acrua system had that
Posted May 01, 2007 · 17:41 UTC#3
the manual calls it a "Direction Line" Its a red straight line the plots from the top of the direction arrow to your destination and its so annoying - reading the manual over again to see if i can get rid of it - so far no luck.
Posted May 01, 2007 · 18:19 UTC#4
Na it's not possible to get rid of it. You'll get used to it eventually. I don't even notice it anymore.
Posted May 01, 2007 · 18:24 UTC#5
its crazy that you can get rid of the bread crumbs but not the red direction line. I find that line more offensive then the breadcrumbs -lol -
Posted May 01, 2007 · 23:07 UTC#6
on the z1 i coulda sworn you can get rid of it.
Posted May 02, 2007 · 11:51 UTC#7
what could that little red line possibly get in the way of?
Posted May 02, 2007 · 12:01 UTC#8
I do not like the red line.I have 2 other Nav units that does not have the red line.I think that why I do not like it.
Posted May 02, 2007 · 14:49 UTC#9
I think it can be turned off on the D1/D2's. I actually like it. It helps in navigating to your destination when you're experimenting w/ new roads. It also helps you find shortcuts.
Posted May 02, 2007 · 17:44 UTC#10
I like it too
Posted May 02, 2007 · 21:09 UTC#11
Agreed whole heartedly...
Mark
Posted May 02, 2007 · 21:33 UTC#12
Are you 100% certain about this? Im almost positive I saw a menu item that allows you to remove it. Let me go back and check the manual
Posted May 03, 2007 · 03:53 UTC#13
The red straight line gives me "Missile Command" flashbacks - an old Atari game from the mid 80's for those of you not as ancient as me.
I would be ecstatic if I could remove...but I guess the designers over at pioneer feel everyone needs to have a red "direction line" across their D3 nav :twisted:
Posted May 03, 2007 · 04:30 UTC#14
At least the line isn't as jagged as the swinging vine in Pitfall. :D
Posted May 03, 2007 · 16:28 UTC#15
Have you tried "settings>Map Display>tracking" then turn OFF the tracking?
Posted May 03, 2007 · 17:22 UTC#16
...that controls the breadcrumbs tracking...not the red line
