D3 requires ground...
By DssHobby · May 02, 2007in Problems/Troubleshooting💬 5 posts👁️ 1,303 views
Posted May 02, 2007 · 09:40 UTC#1
Ok I am confused. I was installing the AVIC-D3 and I notice there is a ground (black cable) comming from the AVIC-D3 wire harness.
My question is:
The aftermarket wire harness for my car indicates there is a ground on it. Can't I simply connect the Avic-D3's ground cable to the aftermarkets ground on the harness? Once I connect the aftermarket harness to the cars harness (Dash). Wouldn't that technically ground the AVIC or do I have to Ground the AVIC to the car somewhere??
Seems logical but I am confused with Pioneer adding that little hook thing at the end of the GROUND cable comming from the AVIC's wire harness.
Posted May 02, 2007 · 11:04 UTC#2
I've grounded the parking brake, chassis ground, bluetooth ground & XM ground directly to the harness on the connector. works fine. if you also see a nut behind your dash you can also loosen it and install the pioneer ground connector to it as well.
Posted May 02, 2007 · 11:30 UTC#3
you can use that wire,its fine
Posted May 02, 2007 · 15:29 UTC#4
They include that "hook think" (spade connector) in case there is no ground wire for your factory harness. They were being thoughtful.
I just snipped that bugger off and tapped into the ground cable of my factory harness. Works like a champ!
Posted May 03, 2007 · 10:38 UTC#5
Thanks guys... I thought that is how it worked but it was one of those days (Brain fart day). Geez you would figure I would figure that out after instaling the AVIC-N1 and doing the MOD. Now the AVIC-D3 (Much easier).
Thanks all for the help!!!!
