Anyone know what wire I tap on the Gauge cluster of an 07' STI for VSS (AVIC-D2)?
Thanks,
Mike
Thanks,
Mike
search, theres a thread here on that or two. you could always search the net for info on the ecu pin outs as well. That would probably be an easier, more clean spot to go for your wires, especially since the reverse is in the pass kick panel anyways.
nasioc.com has all the pinouts of the cluster. I can't give you a direct link but while I was on there I heard it going around. Post a question there and you'll probably get your answer within 5 minutes. There are a 100 000+ members on there.
if it's an '05 and up STI then it'll be the Dark Green/Black wire farthest to your right behind the gauge cluster. I did my D3 last weekend and that's what I used on my '07. Works perfectly fine
