AVIC-Z2 "Back Signal" Connection Status Question
By coldranger · May 03, 2007in Problems/Troubleshooting💬 3 posts👁️ 695 views
Posted May 03, 2007 · 01:35 UTC#1
I'm trying to figure out if tapped the right reverse wire or not. In the "connection status" display, the back signal strength says "high." However, it does not change when I move the gearshift into reverse. Is this the correct setup?
Posted May 03, 2007 · 01:36 UTC#2
if the camera comes on when you shift to reverse then you got it
Posted May 03, 2007 · 01:37 UTC#3
No, it'll say high when you're in reverse and low when you're not.
