Help
By LostHIlls · May 03, 2007in Vehicle Specific Wiring💬 3 posts👁️ 1,152 views
Posted May 03, 2007 · 11:31 UTC#1
Newbie here, I just got the D3 and I am going to install it pretty soon. My question is, where do I find the VSS, PARKING BRAKE, AND BACKUP wires on an 04' GMC ENVOY w/o bose, onstar, and nav? Thanks in advanced.
Posted May 03, 2007 · 14:52 UTC#2
Reverse Light lt. green + fuse box under left rear seat
Parking Brake lt. blue - switch or BCM, blk plug, pin A4
The BCM is attached to the fuse box under the left rear seat.
Speed Sense dk. green/white PCM
4.2L: The PCM is attached to the driver side of the engine. VSS is in the blue plug, pin 32.
5.3L: The PCM is near the lower front driver side of the engine. VSS is in the green plug, pin 50.
Posted May 03, 2007 · 15:28 UTC#3
Thanks for your help. Now I can hook up my Radio!
