2006 VW Passat
By shaneboehm13 · May 03, 2007in Vehicle Specific Wiring💬 7 posts👁️ 1,937 views
Posted May 03, 2007 · 18:23 UTC#1
I received info on the VSS & Illumination wires - but the info is not correct could someone tell me where I can find these 2 wires. The are not:
Speed Sense PURPLE (AC) ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 14 OF A 26 PIN PLUG
PSC/ECU TO THE FAR RIGHT BEHIND GLOVE BOX
Illumination RED/BLACK (+) RADIO HARNESS
Thanx!
Posted May 04, 2007 · 01:46 UTC#2
Illumination GRAY/BLUE (+) RADIO HARNESS
Speed Sense BROWN/RED (AC) IN HARNESS FROM GAUGES
Posted May 04, 2007 · 01:48 UTC#3
Thanx!
Hmm sounds like the info for an older vw.
Posted Jun 14, 2007 · 05:22 UTC#4
Crap, these wires don't work either, My installer said that the illumination is wrong "amperage"? not enough to trigger the unit? VSS not there. Any other suggestions? I have 2006 Passat, V6 w/DynAudio system...
Thanx!
Posted Aug 24, 2008 · 22:59 UTC#5
on my a4, which is similar... i had to get illumination from headlight switch itself(turn it to the off position "O" push in til it clicks and turn clockwise) the wire is grey/blue. as for vss i had to get it from the abs module under the hood. pm me if u need any other help.
Posted Oct 16, 2008 · 06:56 UTC#6
VSS is in also behind the cluster Also can hide the GPS antenna behind the cluster. Illumination at the switch is easiest
